PGR 3 question.....
Discussion in 'Xbox Forums' started by gilford, Mar 19, 2006.
  1. gilford
    gilford
    Feb 12, 2005
    7,611
    Welsh riviera........
    +1,016
    How do you play geometry wars within PGR3?
    Cheers:thumbsup:
  2. Kahled
    Kahled
    Dec 1, 2005
    1,799
    63
    +163
    If you mean how do you find it rather than instructions for play then you need to buy enough cars to open up further garages, not sure if it's the second or third garage you buy. But from that point on you just use the walkaround garage option and you will find the Geometry Wars games by walking up to the arcade machines and selecting them.
    HTH
  3. status
    status
    Every garage haveGeometry wars 1 and 2 :thumbsup:
  4. avinitski
    avinitski
    Apr 22, 2005
    3,319
    +216
    yeah im sure even the first garage has GW 1 and 2 :)
  5. gilford
    gilford
    Feb 12, 2005
    7,611
    +1,016
    Sorted!
    Arcade Player achievement unlocked :)
