Peugeot - Citroen change
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by dhiggs007, Aug 20, 2004.
  1. dhiggs007
    dhiggs007
    I have just brought a Citroen Zantia which has a feeble Clarion radio fitted, and a want to transfer the stereo and cd changer (clarion as well) from my old Peugeot. Will this be a relatively straight forward change as they are both clarion? If not what will I need.?
  2. Cerbera
    Cerbera
    Jul 16, 2003
    22
    I've just put my old Sony stereo into my Xantia, needed faceplate from Halfords (20gbp) and was fairly easy. There is a small ridge that the stereo might get caught on, just needs a bit of coaxing at a slight angle to get over it. Once it does its a nice snug fit. Looks quite good in there too !
