We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Pes 5!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Discussion in 'PC Gaming & Rigs' started by gooner#14, Oct 29, 2005.
  1. gooner#14
    gooner#14
    Jul 18, 2005
    481
    Picked It Up In Town (notts) Today Its Fantastic
  2. gooner#14
    gooner#14
    Jul 18, 2005
    481
    has anyone else got it 1st impressions..... i may reinstall pes 4
  3. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    The Wheldon Road end!
    +8,372
    why would you want to re-install PES4 if 5 is fantastic? :confused:
  4. gooner#14
    gooner#14
    Jul 18, 2005
    481
    i wasnt too sure at first but i been playin for most of the day and its perfect
  5. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    +8,372
    Definately! PES5 is much better than 4 IMO. It takes a few days to adjust fully but I much prefer 5.
  6. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,525
    N.E. Lincs
    +103
    Can it go up to high resolutions? I know with PES4 you were stuck with 1280 x 960 if you wanted to play widescreen. I'd buy PES5 if you could play at 1680 x 1050.
  7. gooner#14
    gooner#14
    Jul 18, 2005
    481
    1280.1024
  8. gooner#14
    gooner#14
    Jul 18, 2005
    481
  9. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,465
    71
    Southsea
    +69
    Is that the Max res :confused: I have just bought this for £18 from play but just sort of assumed it supports 1920x1200.
  10. Searcher73
    Searcher73
    Jun 22, 2005
    215
    Lucky B’s, I am so envious of you all, I can’t even install the dam thing without getting install error message 1628 – guess will just have to re-install pes4 until I somehow work this error out. Don’t hold much hope could be long time though as ain't got a Scooby how to fix this one.
    :confused:
  11. gooner#14
    gooner#14
    Jul 18, 2005
    481
    any one?
  12. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    +8,372
    Ah the joys of PC's, thankfully i've got it on the old X-Box so not of this malarky. That said it looks pretty poor on the box compared to the PC with it's lovely high resolutions.
  13. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    anyone tried the options file yet? to get the team kits etc?
  14. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,518
    167
    Cardigan Wales
    +2,331
    ive edited myself into the inter milan team,love the option available,wristbands,long socks etc
  15. gooner#14
    gooner#14
    Jul 18, 2005
    481
    it says to change ports i need to be a admin how do i do this?
  16. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    +8,372
    Just type in your routers IP into your browser - should be something like 192.168.1.1 and then type Admin in as the user name and leave the password blank in the log in box that pops up.
    Your routers manual will tell you everything you need to know - if you don't have a paper copy then see if you can download a PDF version from the manufacturers website.
  17. gooner#14
    gooner#14
    Jul 18, 2005
    481
    my god didnt realise id have to be a computer buff equal to some1 at nasa to play a game online!!!
    im confused !
    1.type in your routers ip in your brouser???? havent a clue what your talkin about!
    2.routers manual ive searched ntl for the manual to my modem but cannot find anyting!
  18. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    +8,372
    You don't, but if you use a router then you should read the manual on how to use it. The router is not your NTL modem (unless you are using a combined router/modem and not the standard NTL modem) but is a separate box into which you plug the internet connection from your modem. You can then connect several computers/consoles etc, to the router to create a network.
    You will have to explain your set up in detail (i.e. how you connect to the net etc.) before anyone can help further.
    The routers IP address as stated previously is a number such as 192.168.1.1. Your browser is either Internet explorer, Netscape or (the wise choice) Mozilla Firefox and it is the program you use to view web pages. You put the router's IP address in to the browsers address bar (the place where you type a web address) and press enter. This takes you to the log in screen where the user name is admin. No password is required by default.
  19. gooner#14
    gooner#14
    Jul 18, 2005
    481
    oooo my head hurts
    ok im on ntl 1 meg internet which is plugged into my pc by the usb theres a wire going from my modem to a box in the wall also has a dtv and telefone socket and im on internet explorer whats this mozilla?
  20. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    +8,372
    Mozilla Forefox is a better browser (in many peoples opinion) and can be found easily with a google search. Give it a try and see what you think, it's free.
    You actually don't have a router then so not sure why you've got that screen up, unless you tried to start a LAN (local area network - i.e. two or more PC's connected together via a router, say in the same house) game and not an internet game.
  21. gooner#14
    gooner#14
    Jul 18, 2005
    481
    i just go into the game ant then into network!
    how do get into contact with konami about this?
  22. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    +8,372
    Why are you going into network when you are not on a network?
    Isn't their an online option? (I only have PES4 on the PC and PES5 on X-Box)
    There should be details about contacting Konami in the manual.
    What does the manual say to do to play online?
  23. gooner#14
    gooner#14
    Jul 18, 2005
    481
    oops done it turned my zone alarm fire wall off is this safe i have service pack 2 fire wall but is there othere fire walls that i can leave on?
  24. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    +8,372
    Zone alarm is one of the better firewalls. Instead of turning it off you can allow certain games/applications to bypass the firewall (usually by selecting the application that you wish to allow to connect). I don't personally use Zone Alarm so you will have to read how to do this (maybe from their website) but Fierwalls do allow you to configure them like this. Leaving it off will leave you exposed depending on how good your other firewalls are.
  25. gooner#14
    gooner#14
    Jul 18, 2005
    481
    im on the service 2 pack fire wall too
  26. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,344
    2
    167
    +8,372
    It's up to you if you want to risk just using the windows firewall but personally i'd read up on Zone alarm and look to configure that to allow PES5 to work.
  27. dancingmatt
    dancingmatt
    Apr 26, 2005
    433
    +13
    The demo didn't seem to support 1280x720, which PES 4 did natively. Can someone please confirm that PES5 does run in 1280x720?
    That's the native resolution of my Z3 projector, and that'll be luverly... :D
  28. gooner#14
    gooner#14
    Jul 18, 2005
    481
    1280/1024 max res
  29. Pulsar
    Pulsar
    Jan 19, 2003
    3,199
    West Midlands - Stourbridge
    +361
    I don't believe that PES5 supports 1280x720 resolution. I also use my PC with a Z3 projector and PES5 gives the option of selecting 1280x720, but the game won't load in this resolution. I make do with 800x600 with 8xAA.
    Rob
  30. dancingmatt
    dancingmatt
    Apr 26, 2005
    433
    +13
    That's ridiculous - you're saying you can select 1280x720 in the menu but it doesn't work? It crashes? Ignores you?
    I suppose that's something they could fix with a patch, but until they do I'm not buying it. Completely stupid.
    Unless someone else has tried 1280x720 with success?
