Personal views on PQ between Toshiba 28zh46 and Panny TX-28DTX11?
Discussion in 'TVs' started by Image Retention, Jul 14, 2005.
  1. Image Retention
    Image Retention
    Has anyone had a chance to view both these sets on a good signal and, if so, what was your opinion of their picture quality and did either one shine out as being better (in any single way, or overall) than the other. Ultimately, I will have to decide myself but any experience might be valuable in my decision-making process
    Cheers for any opinions!
    Phil.
  2. Howard0000
    Howard0000
    Jan 11, 2003
    953
    28
    Surrey
    +36
    I have the Toshiba and I think the quality is fantastic with Freeview and DVD.
    We have a Panasonic TX28PL10 downstairs, which while isn't the same as the one you are looking at, I wouldn't imagine it's far off. The Toshiba is at least as good if not better. TV certainly looks better, but that might be due to NTL's digital compression.
  3. Image Retention
    Image Retention
    Cheers! I was originally going to be hooking sky+ to it but now I'm sticking with freeview (won't be in the house for very long) I thought the built-in freeview tuner on the Panasonic might be a good plan. That said - if the picture is pretty good on the Tosh, I've got a freeview box anyway and a good scart should do the job!
  4. Howard0000
    Howard0000
    Jan 11, 2003
    953
    28
    Surrey
    +36
    Yeah I think I fancy some better SCART leads for mine.. I'm just using cheap ones atm
