PErsonal PLanner Problem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by WoodyC, Feb 7, 2005.
  1. WoodyC
    WoodyC
    Feb 7, 2005
    47
    9
    Just tried to set the Personal Planner last night for the wife but it wouldn't work. Every time I tried to select a programme from the tv guide it displayed "For your information - there are no programmes in your personal planner". I tried setting it from the bar at the bottom of the screen but nothing happens. Should I try a forced download or is this something other people have had problems with. My box is a Grundig.
  2. FlyHarry
    FlyHarry
    I have exactly the same problem, however my digibox is a Pace.
    It's around 5 years old, I've had the problem for the last 12 months, however could not be arsed doing anything about it until now.
    Anyone help ?
    p.s. I've done the turning the viewing card upside down thing.
  3. JayCee
    JayCee
    Jan 20, 2004
    22,311
    Lanarkshire
    +2,324
    Yes, you have nothing to lose...as long as the dish/lnb/downlead is okay and you are receiving a signal...it often cures weird faults like this.
  4. FlyHarry
    FlyHarry
    I tried a forced software download last night, however it hasn't cured the problem.
    The symptoms are the same as Woody's above.
    Is it possible this could be a hardware error with the digibox ?
    Probably the excuse I need to upgrade to Sky+
    Or are there any other procedures I should try first ?
    thanks
    FH
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Go into the Installer's Menu (Services, 4, 0, 1, Select) and choose "Planner Rebuild", or failing that do a full system reset.
    P.S. Planner rebuild is an option on Sky+ boxes only.
