Percentage free seems too low
Discussion in 'Satellite TV, Sky TV & FreeSat' started by ndenbow, Aug 21, 2004.
  1. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    Hope someone can help. Just tried to do instant rewind and got message on screen indicating low disk space. Went into Sky+ manager and it only showed 1% free. I know this must be an error but decided to start deleting stuff.
    All I have left on my planner is three one hour programmes, a 17 minute programme and some stuff to record tonight. But, it's still only showing 34% free.
    I don't wanto do a system reset (don't know how but I'm sure I can find it) because my wife is in australia and the three episodes I have recorded are not worth risking my life for!
    Any suggestions
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The Planner Rebuild option would be the first thing to try instead of a Full System Reset, it should leave the programs intact and reclaim any "missing" capacity, that's the idea anyway:)
    Services
    4
    Select
  3. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    That did the trick. Many thanks.
  4. Davej50
    Davej50
    Mine is saying I only have 39% free when I really have a good 70% free. I've tried doing the Services - 4,0,1 Select as mentioned above but nothing happens. Option 4 of my services menu is standard Sky setup, number 5 is Sky+ setup but I still don't have any option of doing a planner rebuild. Any ideas?
  5. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    You just have to trust the sequence of keys. Don't look what's on the menu, just press
    Services
    401
    Select
    It works
  6. Davej50
    Davej50
    Yep, i's okay, I've done it now, I wasn't pressing Select :oops:
    All seems to be okay again!
  7. caztime
    caztime
    Thanks just got back 25% of free space.
    so thanks again. :clap:
