People who can put plasma on the wall, nr Norwich
Discussion in 'Home Cinema Buying & Building' started by RaveyDaveyDave, May 20, 2005.
  1. RaveyDaveyDave
    RaveyDaveyDave
    Apr 29, 2005
    28
    As the title suggests, I am looking for a service in the Norwich area, that can put my plasma onto the wall (I have bracket too) and channel/hide all the wires.
    Nothing fancy system wise, I just want an able person to make sure it dont fall off the blinking wall !!! I know people will say its easy, but ive looked and the wall is plasterboard, 5 mil gap then breeze block :eek: . Any ideas guys?
    :lease: :lease: :lease:
    David
  2. aarons
    aarons
    If you only have a 5mm gap to the breeze block you could get long fixings that will fix into blocks which will be solid enough to hold plasma.Other than that if there are battens behind plasterboard cut away size of bracet and replace with mdf and fix to breeze blocks.
