Pentium M based mini PCs
Discussion in 'Desktop & Laptop Computers Forum' started by widescreen, Oct 10, 2004.
  1. widescreen
    widescreen
    Jan 18, 2002
    79
    North Wales
    +4
    I'm looking for a small HTPC that is very quiet but has enough power for FFDSHOW and with a high quality VGA output for my DLP Projector.
    Interestingly I came across www.microcomputers.co.uk that use Pentium M and ATI Radeon M10 graphics. They have tiny cases too which look ideal. Wonder how noisy they are?
    Anybody have any experience of these?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    You main problem will be having sufficient horse-power to use FFDSHOW effectively. If you plan on using resizing and denoising for instance my 3.0 Prescott is maxed-out quite easily only trying 1280x720. For hardware-based playback, ie. TheaterTek with a 9600 fanless an M-class system would be fine, I don't see it being good enough for software-based processing.
  3. widescreen
    widescreen
    Jan 18, 2002
    79
    North Wales
    +4
    This isn't true, I currently use a 2.8Ghz P4 with FFDSHOW Denoise3D and resize to 1440x960 Lanczos 4 and it runs around 90% usage. So the 2Gig Pentium M will have enough power.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    We differ in our observations, with my 3.0 Prescott XP's performance display shows 100% CPU usage, clearly you're using less video processing that I.
    Also, I think you'll find that a 2.0 is somewhat less than 90% of 2.8.
  5. widescreen
    widescreen
    Jan 18, 2002
    79
    North Wales
    +4
  6. supersonic87
    supersonic87
    Dec 31, 2003
    286
    Swansea, Wales
    yes but pentium m's have more cache, and iirc have shorter pipelines which help them perform much faster without the need of hyperthreading
