Pentax Optio 300GS
Discussion in 'Photography Forums' started by Indie57, Apr 14, 2003.
  1. Indie57
    Indie57
    Hi there
    I'm new to the AV Forums and suprise, suprise - I have a quesiton! ;)
    I have just purchased a Optio 330 GS, which I'm very happy with! However, I'm trying determine the best method regarding batteries.
    As it is very new it currently running off the lithium battery that was supplied with the camera, which I understand is not rechargeable.
    I would ideally like to purchase a rechargeable lithium battery but couldn't see this as an accessory for the camera. I thought lithium might be better than normal AA as I tried them and they lasted less than half an hour!
    Basically although I can see it as an official accessory is there a lithium battery (maybe the same one at the 300RS? ) that I could use.
    I'm basically looking for the best option in terms of battery life I guess.
    Cheers!
  2. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Rechargeable Lithium batteries AA are not available as far as know. But Nickel metal hydride ones are. Maplins sell these in packs of 12 for £15 (1900mAh) so with a charger you will be set up for a while.
    What makes the difference in rechargeable batteries is mAh (milliamp hours). The higher the better.
  3. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    Get some NiMh (nickel metal hydryde) rechargeable AA's - they will way outlast ordinary alkalines.
    see the link to 7dayshop in my post to the 'sticky' advice thread above. 2000mAh type last ages (nearly a week!) on my new Olympus camera.
    edit. 2 replies at the same time! At least we agree!
  4. Indie57
    Indie57
    Terrific, thanks guys I appreciate your advice :smashin:
