MysteryM
Finally got my sony hw40es mounted on my peerless PRG unv mount however it's suffering from a horizontal keystoning issue. The right hand side of the image has a smaller height than the left hand side and I just wanted some advise on how best to correct this.
I appreciate that the issue is caused by the projector not being mounted 100% straight in front of the screen (due to either the mount on the ceiling or the bit on the projector not being bang on straight), however I'm assuming that loosening the security bolts on the arms of the mount slightly and rotating the projector could fix it? As that way the projector would then be face on.
My question is, has anyone done this whilst the projector is still hanging as it would be a pain to keep taking it off whilst making adjustments? Just want to be sure that it's safe.
