bazakehurst
I purchased a PEEKTON DVD/DivX PK6022 from pixmania and decided to update the firmware.
Unfortunately the website is French but I navigated my way through and downloaded the update and burnt it to CD. I then asked a very kind person to translate the pdf file to English and it all sounded easy.
I updated it and it seemed ok but then I tested a disc and the sound didn't work. The sound worked fine before the update.
I checked the settings and they all look the same as before. I tried changing them but the sound still didn't work.
It's connected to my TV via scart lead as I don't have surround sound in my bedroom.
Can anyone think what may be wrong with it?
Is there a way to downgrade firmware?
Thank you.
Thank you.
