Pedastal stand for Panny TH37PW7
Discussion in 'Home Cinema Buying & Building' started by Light_User, Feb 28, 2005.
  1. Light_User
    Light_User
    Feb 10, 2005
    305
    +6
    :lease: I am buying a Panasonic TH37PW7, but I am confused as to which pedastal stand I need. I have seen a website which quoted the TYST42PA20 as being suitable, but when I went to do a price comparison, different websites have different pics !! Also, there is a very similiarly named stand - the TYST42PX20. Can I use either stand, or something different and what do they really look like ? Can anyone help ?
    Cheers,
    ps. I noticed some of your threads are quoting prices - digital-point.co.uk are doing this panel + scart board + delivery @ £1059.99 inc vat. They also offer 9 months interest free. Doesn't seem too bad to me.
  2. rickyt
    rickyt
    Jan 7, 2005
    977
    43
    Northumberland
    +113
    I bought a bare bones th37pwt at the beginning of the year without boards/stand etc and then had to search around for all these extras. There were lots on offer at all sorts of prices, Sony did a complete unit stand for over £3000.00 [not sure if that would have fit mine in any case]. Anyway , I went for the RS model for £149.00 [just a tad cheaper than Sony !] and it looks alright.
  3. jabowen
    jabowen
    Dec 28, 2004
    55
    +3
    Lightuser
    TYST42PA20 is definately the one you want - have mine set up on it and am quite pleased. It's a bit more industrial looking than the slimline non-Panasonic one AVSales do, but I actually prefer it.
    As far as I know PX20 does NOT fit the PW7 - but I stand to be corrected if someone knows better.
    Search my other threads and you'll find a link to an ebay seller who sells the PA20 stand cheap as chips - $30 & shipping (which is expensive cos they are blinking heavy). STill mine came in under £80 all in - think a few others used them on the back of my link (ultimateleasing is there username I think).
    Good luck!
  4. Light_User
    Light_User
    Feb 10, 2005
    305
    +6
    Thanks for your comments chaps. I'm not sure though that, "it looks a bit industrial" is going to pass muster with the missus !! - I think I'd best check out the RS and AV sales ones as well, even though they work out at double the price......
    Get it wrong and I may as well :suicide: lol
