Pearlescent white expandable braiding
Discussion in 'Home Cinema Building DIY' started by sticker, Sep 2, 2003.
  1. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Anyone know where I can get hold of this?
    John
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    White is not easy to get hold off - at least not in the UK.
    What size do you need?
  3. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Looking for around 8mm to 20mm or there abouts. Found a french company but they won't deal with the public. Also found a UK co but their minimum order is 100m @ 49p/m.
    By the way Paul the sub cables are really good, much better than the cheap Cambridge ones I was using. Cheers John
  4. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Thanks John,
    I can get White in 13mm to 32mm size. Just checking if I can get a smaller diameter. Send me an email for more info :).
