Pe50 sound improvements
Discussion in 'Plasma TVs Forum' started by Neiluk, Aug 6, 2005.
  1. Neiluk
    Neiluk
    Apr 22, 2005
    Apologies if I am in the wrong topic.
    I have a Panny Th37Pe50, a DMRES10 and Fusion 150 and am really happy with them all.
    When playing music, either digital radio or Dvd's etc, I find that I could do with a bit more bass.
    Is there anyway of adding a sub woofer or do I need to go and get a 5.1 or 7.1 amp, speakers and all the cables that go with such a system? I have wood floors and as I'm renting can not hide any of the cables as I might if the place was mine.
    Any advice would be much appreciated.
    Neil
  2. socrates1
    socrates1
    Jan 2, 2003
    209
    +15
    You could look at getting a Yamaha YSP-800 (one speaker digital sound processor with inbuilt amplifier, which reflects sound off the walls for a surround sound effect) which should be available soon, and a subwoofer for the bass. This will give you surround sound and bass without cables going around the room. Just plug the DVD player and the subwoofer into the YSP-800. I haven't heard it myself but if you do a search for it's big brother the YSP-1 it gets pretty good reviews.
