PE50 rear view for cable routing?
B
Bubblenose
Dear all,
I've managed to get JL to price match a PE50 :thumbsup: which is being delivered Weds. But, before then I'm trying to get the wall bracket mounted and the cable runs done.
I've looked on the web but cannot find any info for the rear view of the panel so that I can prepare the cable runs. Can any one help? :lease:
Also, to keep the audio routing simple, the spec sheet says that there is an audio out from the panel which I was thinking of running into my amp, so that whatever input is selected on the plasma it will route the appropriate audio to the amp...will this work?
many thanks (in advance) Bubblenose.
B
Bubblenose
SteveG - excellent, just what I wanted! Thanks.
Chrisw - agree with your comments; it was just for the VCR and internal tuner. The DVD and NTL box will go direct to the amp. Thanks for your help.
Regards, Bubblenose
A
Ade848
Hi Bubblenose,
What size screen have you ordered. I am trying to get JL to do a pricematch on the 42", I already have the 37" that they pricematched against Hi Fi Confidential.
And I'm in Hitchin. :)
B
Bubblenose
Hi Ade848,
I got the 37", and same as you used HiFi Confidential as the comparison. I would've gone for the 42" PWD8 from AVSales but with the amp the price went through the roof. And of course, with the price match it was sooooo much cheaper.
Another Hitchinite :smashin:
Regards, Bubblenose
B
Bubblenose
I forgot to ask...how long is the supplied mains cable? As I need at the minimum a 3 metre run. :confused:
Cheers, Bubblenose
chrisw
it's probably about 2 metres at best. I bought a 5m one from Maplins and it works fine... also bought an 8 way plug power surge protector thingy just in case...
Trending threads
