PE30 quick question
Discussion in 'Plasma TVs Forum' started by bobbles, Jun 26, 2004.
  1. bobbles
    bobbles
    I have sky+ connected to AV1
    when I turn on sky it auto switches to AV1, fine. However, the display says EC1 not AV1. Anyone know why?
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,631
    London
    +476
    I think it does this when it detects RGB input ?
  3. janmolby
    janmolby
    Mar 30, 2004
    33
    My one is setup exactly the same but doesn't autoswitch. Any idea how i can get it to?
  4. bobbles
    bobbles
    have you set the TV scart on sky to AV1 on Plasma?
    That is how I have it set up and everytime I switch on sky it autochanges to sky. It doesn't do it for my dvd player connected via component or my dvdr connected to AV2 SVHS scart. Not sure about xbox.
    You can set the TV to switch on to whatever AV channel it was last on.
