PE30 de-interlacing Sky+ (cinema mode)
Discussion in 'Plasma TVs Forum' started by spook, Jun 13, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Hi all, I understand that the panny 42 PW6 has a feature called "cinema"? am I correct in assuming that this de-interlaces a standard interlaced rgb signal?
    how well would this work with sky+ signal using standard scart rgb connection?
    does the 42 PE30 also have this "cinema" feature?
    cheers, spook
