PDP435XDE Sky+ Connection?
Discussion in 'Plasma TVs Forum' started by sparkz, Nov 4, 2004.
  1. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    To those 435/505 owners with Sky+.
    I'm looking to upgrade my 433 to a 435 soon. I've seen comments about the screen not being brilliant with sources such as Sky.
    How do you connect your Sky+ box? Do you have to convert svideo to something else?
    Thanks for any input :)
    Mark
  2. rajvirdee
    rajvirdee
    I believe you get a good quality scart cable (all pins connected) and connect that to the media box. Its as simple as that!
    Set the sky box to RGB and away you go.
  3. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    rajvirdee, thanks for that.
    I was going to use the svideo to svideo connection as I do with my 433. Somewhere (I can't find it now) I saw some talk about getting a better picture by converting to component. Don't know if this results in anything which is noticeable better?
  4. rajvirdee
    rajvirdee
    I have ordered the 668 with the 435 XDE and sky + so a similar setup to you, and contacted JS (who make converters) and his reply was for me to stick to the RGB route, which should produce slightly better results than Y/C svideo.
    you could get a ls convertor to convert from svideo to component, but I can't see how that will yeild better picture quality.
    ...HOWEVER I MAY BE WRONG !
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,767
    The Borders
    +3,287
    sparkz
    SKY+ into the R05 Media Box is straightforward enough - as rajvirdee suggests a decent quality SCART cable and set the SKY+ to Output RGB and the Media Box to Input RGB; no senses whatsoever in messing around with S-Video or any form of converter.
    'Upgrade' may not be the best way to describe a move from a PDP-433HDE to a PDP-434HDE or the latest PDP-435XDE - there's been lots of tweaking and adjustments and the XDE has a new screen filter technology but the basics are quite similar.
    I'd talk through any areas your dissatisfied with with a dealer to assess if the XDE is your best move.
    Best regards
    Joe
  6. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    Thanks, that's interesting Joe and rajvirdee.
    I don't know where I got this idea that svideo was better than the straight rgb. I am using both (one for recording and viewing elsewhere) but for some strange reason I've got svideo to the plasma.
    Joe: Not too sure if Pioneer would consider a 10% increase in brightness, 20% increase in contrast, increased colour range (7 billion) and HDMI tweaking? Take your point though.
    Mark
  7. key130
    key130
    Mar 21, 2004
    33
    Manama
    Mark - I have a sky box connected to my 435xde using a scart lead. It's not an expensive lead.
    I am happy with the picture. I may spend a few bob more later on to get a good quality lead, but am in no hurry.
    Al.
  8. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    Al: Thanks for that. RGB scart it is then...
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,767
    The Borders
    +3,287
    Hello sparkz
    As you say the busy beavers back in Japan would be aghast at such a suggestion - then again if I built a false wall with 3 x 43" apertures and lined up a 433HDE, 434HDE and a 435XDE behind the false wall such that you couldn't see which TV was which and played in an HD signal I wonder how quickly they could identify which generation of screen was which.
    Regarding SCART RGB - you have three options:
    01. Fully Wired SCART cable - will transmit your RGB signal plus all the other signals SCART can transmit including Stereo Audio if you intend to use the TV's speakers.
    02. RGB Only SCART cable - built with heavier cross section conductors and heavier screening; these only transmit the video signal.
    03. RGB+Stereo audio Only SCART cable - the video quality of 02 with the added bonus of Stereo audio.
    Best regards
    Joe
  10. Tantalus
    Tantalus
    Aug 21, 2003
    289
    Aberdeen
    +3
    Been looking at getting a RGB+Stereo audio only scart cable but can't find one. Any recommendations? How much should on spend?
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,767
    The Borders
    +3,287
    Tantalus
    The Supra AV6.4 does what your after - SRP is £109.99.
    Best regards
    Joe
  12. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    All the usual suspects should be able to sort you out, eg Keene or Lektropacks.
  13. teoterone
    teoterone
    I wouldn't go nuts on a scart cable if I were you, just get a good quality QED squart for under £30 and you're good to go.
    Like this http://www.hifistore.co.uk/product.php?qsProd=P4110
    Its an excellent cable and will be good to use until HDMI arrives in 2006.
