PDP435XDE connections
Discussion in 'Plasma TVs Forum' started by MikeW, Mar 18, 2005.
  1. MikeW
    MikeW
    Mar 17, 2005
    4
    UK
    :cool: I am almost certianly going to purchase a PDP435XDE in the next month or so and I was pondering over my connections. Initially there should be no problems when I am playing DVD's and games as I have a Sony DAV-S800.
    The problem comes when I want to get a HDMI DVD player (definitely needed) and still have the sound coming through my Sony DAV-S800 surround sound system? Forgive me for being naive, but if I connect a HDMI DVD player to the plasma screen and then output the sound to my DAV-800 it will no longer be in 5.1 sound? Is there an easy fix or will I need to purchase a new dedicated surround sound receiver. :cool:
  2. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Hi Mike,
    I was in the exact same position with the same tv and same Sony DAVS800. Bought a HDMI DVD player to view the picture and I have a digital optical cable running from the DAVS800 into the dvd player. I changed the sound output on the dvd player from pcm to bitstream and now I am getting dolby digital/dts from the DAVS800 (Well I havn't had a chance to watch a film in full yet but it says dd on the front display).
    I now need an optical switcher so I can switch the sound from dvd to sky when needed.
    Hope this helps.
  3. MikeW
    MikeW
    Mar 17, 2005
    4
    UK
    Cheers BIGMAX for your prompt reply. What you said sounds really good! I'll have to give it a go when I purchase the plasma tv. Incidentally, what was the picture like before you bought a HDMI DVD player?
  4. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    To be honest the picture from the Sony dav through svideo was excellent and when I first played the dvd on the hdmi (samsung hd945) it was only slightly better. But since then I have had a chance to fiddle with the settings and I can say that the hdmi picture is fantastic. Well worth the cheap price of the dvd player. It's amazing what a difference playing around with the settings does for the different inputs.
  5. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    glad you got sound sorted bigmax :smashin:
  6. BIGMAX
    BIGMAX
    Jan 11, 2005
    747
    +18
    Cheers Mep, I've posted my thanks on the dvd forum for your tip. Its good to be able to pass on good advice kindly given in these forums.
