PDP 505XDE - Hours Of Usage
Discussion in 'Plasma TVs Forum' started by SPURS1882, Apr 5, 2005.
  1. SPURS1882
    SPURS1882
    Sep 16, 2004
    368
    Gants Hill
    +16
    Hi Guys
    Can anyone tell how to access the "Hours Of Usage" on the PDP 505xde.
    Michael :confused:
  2. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    Put the screen into standby
    On the remote, press the button under [9] and release it.
    Wait 3 seconds.
    Then
    , [up],
    , [standby].
    When the panel comes out of standby you should be in the service menu. Use the arrow keys to navigate to the hours of use page, then put the screen into standby to exit the menu.​
  3. SPURS1882
    SPURS1882
    Sep 16, 2004
    368
    Gants Hill
    +16
    Cheers Kier
  4. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    No problem :)
  5. richardb70
    richardb70
    Mar 2, 2005
    4,935
    Reading
    +2,196
    I wish I could get this working on mine! Is there a "knack"?
  6. hillster
    hillster
    Feb 11, 2004
    719
    Reading
    +29
    It does work, sometimes it happens first time but more often than not you'll need a few attempts...
  7. Niraj
    Niraj
    Join the club mate :)
    Of the 10 or so times I've tried, I've managed it only once......need to see how close I am to the 200 hour figure so that I can arrange the ISF calibration :clap:
    Niraj
  8. MR ETOME
    MR ETOME
    Nov 11, 2004
    107
    +8
    Niraj,
    Try doing the first step twice i.e. put screen into standby then press and release display button wait 3 secs press and release display button wait 3 secs then left, up, left, right switch on.
    I had same problem as you, works every time now.
  9. jubletroop
    jubletroop
    Mar 1, 2005
    13
    Southsea
    Hi All, :hiya:
    Will this work for the PDP 435 XDE too? I want to see how close I am to the 200 hours as well. :smashin:
    Cheers.
  10. johnnycab
    johnnycab
    Jan 26, 2005
    84
    Yes.
