PDP-43MXE1 FRC Modes?
Discussion in 'Plasma TVs Forum' started by Kaz, Oct 27, 2004.
  1. Kaz
    Kaz
    I've read here (and in the Integrator Manual) that the FRC Mode 2, allows a wider range of acceptable refresh rates.
    But with my set it seems that FRC Mode 1 allows more (down to 50Hz from a PC on the DVI input, although not without some sizing errors).
    In Mode 2 the picture disappears and is reported as "out of range" as I reduce the Hz in Powerstrip on my PC.
    In Mode 2 I can't get HD 50Hz signals from our xbox. But in Mode 1 I can. And in Mode 1 you get all the Picture in picture functions.
    Why might this be? And why's might the image be squished to the side in Mode 1 at 50hz?
  2. philipb
    philipb
    Mar 6, 2002
    2,096
    63
    Swindon
    +173
    Which graphics card are you using?
  3. Kaz
    Kaz
    Radeon 9600 256mb Passive (powercolour iirc)
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Kaz it's what the modes do with the signal rather than what they allow. Mode 1 converts everything to 72 odd Hz, mode 2 leaves 59.94Hz and 50Hz alone (or converts 50 to 100, can't remember!) and mode 3 if for 24/25fps HD cameras.
  5. philipb
    philipb
    Mar 6, 2002
    2,096
    63
    Swindon
    +173
    I had 50Hz from a 9600 using mode 2 no problem. Nvidia cards are a problem but ATI should be OK. It may be the card - or try reinstalling the drivers. Is it the latest version of powerstrip?
    Liam - I'm not sure anybody knows quite what the Pioneers do in the 3 FRC modes. Certainly a 50Hz input is very smooth, so I suspect there is no conversion going on.
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,215
    +3,068
    FRC3 moce is for HD cameras taht playbacka dn record at 24 sfP and 25sfP I believe.
    No pip with FRC2 as it's not possible to mix two different refresh rates on screen at the same time...ie if you have R1DVD on and want to see PIP of a PC or perhaps PAL TV....With FRC1 it's not a problem as it's all turned in to 70Hz.
    Gordon
  7. Kaz
    Kaz
    thanks chaps. I'll have play with the drivers for the card then (getting a bit HCPC forumy..).
    It makes sense what you're saying about the modes. I've gone back to Mode 2 for TV viewing and will select Mode 1 for XBOX HD viewing.
