PDP-435XDE and PDP-435FDE differences?
Discussion in 'Plasma TVs Forum' started by WSH, Dec 19, 2004.
  1. WSH
    WSH
    Apr 13, 2002
    1,014
    28
    +39
    I cannot make out the difference between the PDP-435XDE and PDP-435FDE. Can anyone help?
  2. pib01
    pib01
    Dec 11, 2002
    52
    littlehampton
    pdp-435xde has built-in freeview receiver,otherwise they are identical
  3. WSH
    WSH
    Apr 13, 2002
    1,014
    28
    +39
    So there is little point buying the more expensive one since a freeview box is around £50.
  4. sjb
    sjb
    Jul 1, 2004
    114
    S.E. Scotland
    The remote control on the XDE is metal whereas I believe you get a plastic shot with the FDE.
    There are a few other differences aswell ( photo gallery option etc... ).
    Given the choice I'd go for the XDE ( infact I did ). :thumbsup: :thumbsup:
    Check the Pioneer website for other differences or search this forum
    Regards,
    Stan
  5. seaco
    seaco
    Oct 13, 2004
    113
    Somerset
    +5
    Plus picture in picture and split screen on the XDE and optical digital!
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    And the digital picture on the XDE is way better than the FDE can achieve with a freeview box on a scart socket. These screens only really shine with an HDMI external source.
