Pdp-434hde > Pe????
Discussion in 'Plasma TVs Forum' started by saytaan, Dec 11, 2003.
  1. saytaan
    saytaan
    Hai, received mine yesterday, still in the box but saw on the box the type PDP-434 PE?
    What is the meaning off this type speq because on the side the normal PDP-434HDE type is alsoo mentioned.....
    :confused:
    Pioneer ax5, 434HDE, waiting for 868, kef 2005.2
  2. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    Dunno, but my 504 had PE on one side and HDE on the other side as well.
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    There's separate codes for each separate bit, the collective code for the media box plus the screen is 504HDE.
