PDP-4280XD and HTPC...any good?
Discussion in 'Plasma TVs Forum' started by Ferret face, Jan 20, 2008.
  1. Ferret face
    Ferret face
    Jan 17, 2008
    16
    Hi Guys,
    This is my first post on this wonderous forum and am considering buying the Pioneer 42inch but would like to know if its any good for connecting a HTPC to?
    I will want to watch my Bluray movies and some mkv files from a pc, however I have read that the pioneer is not true HD and has a weird resolution with rectangular pixels.
    My question is...will the picture from the pc be sharp and clear or will it be blurry due to weird resolution/refresh rates?
    I have tried searching the forums and am a bit baffled so any help will be much appreciated..
    Thanks!
  2. Rob_Meister
    Rob_Meister
    Sep 14, 2006
    1,261
    East Farleigh, Kent
    +93
    Do you know what the screen in questions model number is?
    These rectangular pixels you speak of are not going to be so obvious that the screen appears blury.
  3. Ferret face
    Ferret face
    Jan 17, 2008
    16
    Yes its the Pioneer PDP-4280XD 42inch Kuro and I have read it cant do 1:1 pixel mapping so my question is...
    is it any good for HD and SD via a HTPC or is it better to get a 1080P set like the Panasonic PZ70?
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    In this case it might be 'better' to get a Pz, you have other problems besides pixel mapping. Overscan is a big big problem with 4280s and PC via HDMI, no visible talk bar for 1 thing, so MCE only as an interface. You can do 1.1 mapping with the Pz, it would solve a fair few problems in one go.
  5. Ferret face
    Ferret face
    Jan 17, 2008
    16
    Wow thanks Maw you just saved me a bucket load of money,
    I didn't realise that the Pioneer was so poor with a pc source, shame really but it looks like it will have to be the Panasonic then if they are superior for image quality.
    Many thanks for the info
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    As I said, it's not that it's shockingly bad for PQ, not perfect, as you'd expect for a fixed pixel display and a non matched PC res, the overscan is a killer though. The PZ has a pixel for pixel mode, you just turn that on and that's it done for PCs.
  7. un1eash
    un1eash
    Nov 14, 2007
    5,003
    2
    +1,421
    50PZ70 is awesome for HTPC, ive got mine set up to 1:1 mapping at full 1080p. Only problem is i cant get 24i/25i/30i as it causes juddering, 60hz looks great though.
  8. Heavysalad
    Heavysalad
    Dec 27, 2005
    704
    46
    +91
    I'm considering swapping out for a 4280XD (from a PZ) and am interested in how the Pio will hook up to a PC... as much fro PC gaming as anything else. Its not the deal breaker but it would be nice to know I'd not be drasticaly downgrading in that dept..
    Is this quote any use from *... ?
    " Overscan..
    When fed with supported resolutions, you can achieve zero overscan in the [PC] mode over VGA (after "Auto Adjust") and HDMI, but because white balance controls, film deinterlacing and colour management system are disabled in this mode, I'd avoid it at all costs. "
    So... if you hook up via VGA will PC, taskbar and all will be displayed fine with overscan disabled?
    Is the fact that these features are disabled detremental to the quality of the PC image.
    I'm thinking he's saying 'avoid it at all costs' re: trying to achieve 1:1 pixel mapping in this way to view sources other than actual PC display ?
  9. Ferret face
    Ferret face
    Jan 17, 2008
    16
    Heavysalad can I ask why you are getting rid of the pz?
  10. JimBob1971
    JimBob1971
    Jan 12, 2004
    2,528
    +739
    I own a 428xd. The overscan issue isn't a problem for me - It can be changed on my graphics card so that I see the entire screen. Also, players such a Media player classic allow tailoring of output size using a few keystrokes, so I never lose any information offscreen
  11. Bumtious
    Bumtious
    Oct 26, 2005
    8,126
    Prestwich Manchester
    +7,650
    Err
    The 4280 will do 1:1 pixel mapping with zero overscan via vga or hmdi in pc mode.
    Only issue is it is a 1024 by 768, you can map to that but that is a 4:3 resolution so the image is streached but maps properly.
  12. Ferret face
    Ferret face
    Jan 17, 2008
    16
    So if the image is stretched on the Pioneer then films and video etc may look a bit blurred ?
    If i am wrong about the Pioneer then can someone please explain\assure me that HD and SD video will look fine on the Pioneer via HTPC otherwise it looks like the Panasonic pz is the only choice for a 42 incher.
  13. LCR_Dave
    LCR_Dave
    Jun 27, 2005
    1,441
    +74
    i would say gor for the pz, i don have a 428 but i have a 427 and getting the picture to fit on the screen is just an absolute nightmare ive spent hours doing it so you dont get overscan or stretch, and then it still looks pants! i can only guess the 428 is the same, for ease go for the pz
