PDA with Compact Flash & BT & Wi-Fi
Discussion in 'Mobile Phones Forum' started by cerebros, Apr 18, 2004.
  1. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    Does anyone out there know of any current Pocket PC PDA's with Compact Flash slots, Wi-Fi & Bluetooth?
    Everything seems to be going towards using SD instead of Compact Flash, which isn't much use for me.
    thanks
  2. shoehorn
    shoehorn
    Jul 2, 2003
    1,602
    The Garden of England
    +32
    How about something along the lines of the IPAQ 2210?
    It's got compact flash and SDIO slots (along with bluetooth and IDRA) so you could get a Wi-Fi card for the SDIO slot!
    AND it can act as a remote control - along the lines of a Pronto!
    Review here
  3. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    That's what i was looking at initially, but an SD Wi-Fi card adds about £100 to the total cost which is why I'm trying to find an integrated PDA as that will presumably be cheaper than buying one with only one connection standard and then adding a card for the other type.
    (e..g, I've seen the 2210 for £214. Add £100 for Wi-Fi SD card so i can still use the CF slot and you're looking at £314. iPaq 4150 which has Wi-Fi & BT but only SD slot is £250... If it had CF instead of SD I'd be snapping one up...)
