pda remote
Discussion in 'Mobile Phones Forum' started by sc1977, Oct 7, 2005.
  1. sc1977
    sc1977
    Jul 16, 2002
    616
    kent
    +8
    which is the best ipaq for use as a remote control
    obviously looking at nevo enhanced
    anybody had good results from any particular model?
    thanks
    stu
  2. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    Londoner living in Doha, Qatar
    +139
    Don't know about IPaq specificaly but the IRDA ports in portable devices are generaly very low powered.
    The little i've played around with this I found it to be a bit pointless as I had to get so close for the narrow beam/lowpowered IRDA to get a signal through that I could almost just reach with my arm You may not have much luck with it as a practicle device :D
  3. Crocodile
    Crocodile
    Nov 4, 2002
    18,325
    +6,858
    2210 has consumer grade IR & has Nevo pre-installed. Discontinued now though but readily available from Ebay.
  4. Ice Master
    Ice Master
    Is there any place i can get hold of nevo, supposadly it supposed to come with all/most ipaqs. I got 2 ipaqs and neither of them have it installed or on the disk.
    Any ideas?
  5. Crocodile
    Crocodile
    Nov 4, 2002
    18,325
    +6,858
  6. sc1977
    sc1977
    Jul 16, 2002
    616
    kent
    +8
    nevo enhanced ipaqs
    series 2200
    3950
    3970
    5400
    rx3100
    rx3400
    rx3700
    im looking at geting rx3715 hopfully missus will get me it for christmas (longshot her getting the right one though lol)
  7. jameslindsey
    jameslindsey
    May 21, 2003
    410
    +20
    I use an IR extender CFcard with my old iPaq 3630 in the CF jacket. Old iPaqs can be picked up very cheaply off ebay and if all you want it for is a remote then ther'es no probs getting an old one.
    Check out the TV remote controller at
    http://www.pdawin.com/
    If used in CCF mode allows you to use all the resources of the Philips Pronot series remotes.
    Would heartly recommend Pocket gear for the download of the software
    http://www.pocketgear.com/
    And also the ir extender available here:
    http://www.laser.com/?laserlink=ahpda-ir
    Also there is a huge archive of layouts and codes availble here
    http://www.remotecentral.com
