PDA As Remote - screen damage
Discussion in 'Home Cinema Control & Remote Controls' started by McBain, Aug 7, 2003.
  1. McBain
    McBain
    Feb 15, 2001
    156
    Fair Oak
    All,
    After Messiah's excellent discussion of how great his Axim /w PDA-IR is, i'm seriously considering going down this route as opposed to a Pronto.
    However, I'm concerned about using the PDA as a touch screen remote. Bear in mind that my previous experiences of PDAs are as personal organisers etc. They ship with a stylus for operation, and people are usually extemely protective about the screen - wanting to keep scratches to minimum etc. There's no way that normal usage of a PDA invloves touching the screen with your fingers. As far as I know, you cant just usually replace the screen - its whole new PDA time.
    Anyway - can anyone with experience of PDA (Axim particularly) as a remote comment on how their screen is holding up? Do people use screen protectors of any kind, or are you all just going to replace the PDA when the screen gets buggered?
  2. fufna
    fufna
    In my experience, PDA screens are pretty tough (the come with a protective coating from the factory)
    You finger is going to be a lot easier on the screen than a more pointed object anyway (ie the stylus designed for it!)
