PDa 5002
Discussion in 'Plasma TVs Forum' started by LeonidS, Jul 20, 2003.
  1. LeonidS
    LeonidS
    Feb 11, 2002
    70
    Guildford
    HI
    could somebody tell me urgently what is the VGA socket on PDA 5002 (Pioneer 433MXE) male or female?
    Thank you
  2. tbrar
    tbrar
    May 31, 2003
    609
    16
    Hi LeonidS
    There is no VGA input on the PDA5002 board.
    However on the panel itself - female.
    Tony
  3. LeonidS
    LeonidS
    Feb 11, 2002
    70
    Guildford
    The reason why I am asking is that I need to get a VGA cable...
    So with Js Box I need a VGA cable with two male sockets? Right?
  4. tbrar
    tbrar
    May 31, 2003
    609
    16
    If youre going VGA to the display, from the JS Box, then yes you will need cable as specified.
