PD7200 and Pc Connection
Discussion in 'Plasma TVs' started by Miander, Jul 14, 2005.
  1. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    HI Peeps!
    Well the 7200 is coming on well nice now... all is well! untill my sky box blew up! wellnot blew up just died.
    that aside
    Ive got my pc set up in the living room now.. and well. I am currently using a Dsub 15pin connector which gives me a nice pic
    Puta is running 1024 768 / 85hz
    now.. i was going to buy a DVI - DVI cable. Is this going to give me any significant advantages?
    Also... whats the best PC setup for use on the plasma (screen res etc)
  2. chimpmagnet
    chimpmagnet
    May 26, 2005
    274
    +6
    Sorry just to ask -- all you need to connect a PC/laptop to your 7200 is a 15 pin Dsub?
    I guess the lead has to be quite long also given that the PC might sit some way froom the TV?
    Thanks... I've been looking to do this myself.
  3. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Yeah i got the Dsub connection fine!
    but my gfx has a DVI! and i was guess it would be a far better image than the old dsub!
    I was wondering if it would make a diff and what sort of screen res etc to use
    i got a 4 m dsub! working fine
  4. peterho
    peterho
    Jan 21, 2005
    58
    east yorks
    +8
    Hi will the 15 pin dsub to the 7200 carry hidef video clips from microsoft site,not sure if input on hitachi supports 720p50.I only have dsub output on my sony laptopIf not can you buy a dsub to component connection and come in on av4 which the manual says does support 720p.
