Pd50 Service Menu
Discussion in 'General TV Discussions Forum' started by PUD the Ancient, Jan 24, 2005.
  1. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,669
    notts
    +154
    Can anyone tell me how to get into the service menu and how to adjust the picture to the right. Any input would be greatly appreciated.
  2. eXOBeX
    eXOBeX
    Service Menu 1
    Set the bass to maximum
    Set the treble to minimum
    Whilst pressing V on the front panel, press INDEX on the remote
    Service Menu 2
    Switch to channel 99
    Switch to AV (makes it easier to stay on channel 99 when doing the next step)
    Go to the last option in Service Menu 1
    Press HOLD
    Fastext buttons navigate and adjust, STR button stores setting (if you move from one setting to another the altered value is lost unless you STR it first).
    p.s. you REALLY don't want to screw around with the set of hex values in Service Mode 2, they'll mess around with your menu, disable features that exist, enable features that don't exist, and worse.
  3. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,669
    notts
    +154
    Thanks very much for the info.
  4. benbtg
    benbtg
    Jul 14, 2005
    29
    Could these Hex values in service menu 2 be the key to enabling HD support on the PD50's?
    Clutching at straws?
  5. hossacd
    hossacd
    Jun 28, 2004
    115
    +17
    The PD30/50 are available in Australia (different model numbers though) which are HD enabled on the component inputs, there has been rumours that a firmware hack on the UK model or even updating the UK set with the Australia firmware will enable HD and a couple of folk have mentioned a HD hardware upgrade for the PD30 but I have never heard of anyone sucessfully getting a UK PD30/50 to display HD, it would be nice though as there are a few boxes about now that convert HDCP HDMI to component or remove the HDCP and pass on the HDMI.
  6. benbtg
    benbtg
    Jul 14, 2005
    29
    Sounds promising, I think. :rolleyes:
    But how on earth does one do a firmware update? Wheres the interface?
  7. hossacd
    hossacd
    Jun 28, 2004
    115
    +17
    I suspect it would be through the infra red port for the remote could be done with a laptop with a IR port, I remeber folk region hacking Sony DVD players this way after downloading the hack off the internet.
  8. benbtg
    benbtg
    Jul 14, 2005
    29
  9. Golfpunk
    Golfpunk
    Feb 10, 2005
    383
    Surrey
    +4
    Great - I've been googling this for ages to try and get it. Just got a copy of DVE as never been truly happy with the picture on the PD50 and I swear that the pincushion is going worse every day. Seem to get a slightly funny bending when the Sky banner comes and goes.
    I think the rumour of the HD firmware upgrade will go down in history along with "rat in KFC" and "man juice in girls curry"...... :devil:
  10. benbtg
    benbtg
    Jul 14, 2005
    29
    All true! ;)
    So the HD PD50 mod must be too! :clap:
