PD50 problem with 480p
Discussion in 'General TV Discussions Forum' started by PUD the Ancient, Jan 11, 2005.
  1. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,669
    notts
    +154
  2. zlatan-italian
    zlatan-italian
    Nov 4, 2004
    36
    What's the problem?
  3. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,669
    notts
    +154
    If you look at the text it is casting shadows, like a double image.
  4. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    How long are your cables? Looks to me like ringing
  5. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,669
    notts
    +154
    What is ringing ?
  6. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Ringing is an electromagnetic effect caused by an unterminated (or badly terminated) signal cable. In simple terms it causes the signal to bounce up and down the cable almost like a spring. It can be caused by a cable that is too long, coiled up, or the wrong impedance. Are you using a quality cable, and is it particularly long or coiled up?
  7. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,669
    notts
    +154
    Thanks for the info. I was not the one that originally reported the problem but I am interested in the pd50 and picked this problem up on the forums in a previous thread by shadow. I wanted to pursue it as no one responded to shadows question.
    Thanks again.
  8. Shaddow
    Shaddow
  9. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Shaddow have you tried a different cable, or a different source?
  10. Shaddow
    Shaddow
    I only have xbox with progressive scan output....I dont have dvd player with i can test it. I try with others cables (only RCA cables, i dont have other HD pack for xbox) with the same result.
  11. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Hi Shaddow, looks like the gamester lead is the problem...
    Do a search for 'gamester ghosting' (ghosting is how to describe your problem). It seems many people have seen this with the gamester at 480p. Fix seems to be to get the official MS cable... Check out the X-Box forum, there are a few posts describing your exact fault
    http://forums.xbox-scene.com/index.php?
  12. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
  13. Shaddow
    Shaddow
    thanks, i will buy official MS cable
  14. Shaddow
    Shaddow
    A friend has left to me dvd player with progressive scan. I can play some dvds with component+progressive scan without problems :)
