Question PCM v Bitstream quandary
Discussion in 'AV Receivers & Amplifiers' started by nickymarshall, Jan 7, 2017.
Tags:
  1. nickymarshall
    nickymarshall
    Oct 12, 2008
    1,048
    +198
    Hi - I have an old Yammy A763, so I don't pass through much stuff, as my BD & TV are 4k.
    A brief description -
    Sky to Amp via Optical
    Sky to TV via HDMI
    BD to Amp via HDMI
    BD to TV via HDMI
    XB360 to Amp via HDMI
    Amp to TV via HDMI
    I'd like to send the signal from my BD to the Amp in Bitstream, so that the Amp decodes HD Codecs. It doesn't seem that the HDMI out's are individually selectable PCM/BS, so that means sending Bitstream to the TV too (the mrs may want to watch a disc without the amp on, so have to be able to send sound to TV. Selecting BS on the TV inputs means that I can't hear Sky - going into the Sky menu, there are no options, so I presume this is PCM
    So, is there a workaround, or should I just keep all sources happy and send PCM to my Amp?
    Thanks to anyone that understands my rather dodgy explanation
  2. andym81
    andym81
    Nov 13, 2016
    439
    28
    GB
    +81
    Bitstream everything. Especially on bluray
  3. nickymarshall
    nickymarshall
    Oct 12, 2008
    1,048
    +198
    If I set every input/output in my system to bitstream, then I get no sound to the tv from Sky (no option to set Sky HD to BS)
  4. andym81
    andym81
    Nov 13, 2016
    439
    28
    GB
    +81
    What receiver have you got
  5. nickymarshall
    nickymarshall
    Oct 12, 2008
    1,048
    +198
    Yamaha AX763
  6. andym81
    andym81
    Nov 13, 2016
    439
    28
    GB
    +81
    I've got onkyo 646 and when in pcm audio from my ps4 it sound awfully compressed compared to bit streamed.
  7. dante01
    dante01
    Mar 5, 2009
    45,164
    +10,617
    Even though it the exact same audio? Nothing has been compressed and the only difference is which device is decoding the audio. If you bitstream the audio then the AV receiver decodes it and inputs the resulting PCM data into its DAC. If outputting the digital data as PCM from the source then the source is decoding the audio to the receiver as PCM. PCM is lossless uncompressed digital data.
    Whether you bitstream the audio formats or have the source decode them and output the data as PCM, both result in exactly the same audio.
  8. andym81
    andym81
    Nov 13, 2016
    439
    28
    GB
    +81
    If you pcm the device is decoding. If you bitstream the av is doing it basically. The average does a far better job from what I've herd
  9. dante01
    dante01
    Mar 5, 2009
    45,164
    +10,617
    SKY boxes have two digital audio output options. One option is to output Dolby Digital if and when present while the other is to only output all audio as stereo PCM irrespective of the audio format present. SKY HD boxes usually have such a setting for both their HDMI and their optical audio outputs.
  10. dante01
    dante01
    Mar 5, 2009
    45,164
    +10,617
    You've heard wrong. Both result in exactly the same PCM digital signal. As I said, the only difference is which device decodes the compressed audio format to digital PCM data.
    Blu-ray Disc Audio - Bitstream vs PCM Output - Which Is Best?
  11. andym81
    andym81
    Nov 13, 2016
    439
    28
    GB
    +81
    I've tried films in both an by my ears letting the receiver do it makes a lot of difference. This is in my opinion
  12. dante01
    dante01
    Mar 5, 2009
    45,164
    +10,617
    You can effectively send both audio and video via HDMI to your TV from the SKY box and the additional optical connection isn't required. Connect the TV's optical output to the AV receiver and passthrough the audio associated with your SKY box to the receiver. Ensure you set the TV's speaker setting to OPTICAL. You should be able to set the SKY box's HDMI audio output to Dolby Digital and the TV should be able to pass this through to your AV receiver via the optical output.
    Your UHD BD player does allow you to configure it so that only video is output via the video HDMI output while only audio is output via its audio HDMI output. Connect the video output to the TV and the audio output to the receiver. Configure the player so that only video is output via the video connection and so that audio is bitstreamed via the audio HDMI connection to the AV receiver. Your TV doesn't have the audio abilities that your AV receivers has so the player takes the least capable device as guidance for the audio it can output. If you were to use the connection from the player to the TV to convey audio to the TV in tandem with the connection to the receiver then both outputs would only output audio the TV can handle. I'd advise only using the AV receiver to handle the audio from the player and not to output audio from the player to your TV. If you do then you'd be restricted to Dolby Digital or stereo PCM.
    Still make an HDMI connection between the TV and the AV receiver for any other legacy devices you may want to pass video from through the receiver to the TV.
  13. dante01
    dante01
    Mar 5, 2009
    45,164
    +10,617
    Get your hearing checked. Sorry if I'm coming across as being rude, but the fact is that the audio is exactly the same audio irrespective of which device does the decoding. Both result in the exact same PCM data and it is just a matter of the receiver not indicating the fact the formats are decompressed by it resulting in the same PCM data.
  14. andym81
    andym81
    Nov 13, 2016
    439
    28
    GB
    +81
    Yea i must need them checking
  15. Captain Ron
    Captain Ron
    Jul 6, 2007
    2,045
    114
    +1,005
    I have a similar setup and the solution is indeed to make tha av receiver do all sound duties and only send video to the display. The ergonomic difficulties with this are that you need to be comfortable with juggling lots of remotes or have the time to setup an intuitive activity based solution on a universal remote. It is worth spending the time to do this.
  16. dante01
    dante01
    Mar 5, 2009
    45,164
    +10,617
    I'd maybe suggest investing in a Logitech Harnony remote. One Harmony remote will control multiple devices.
  17. nickymarshall
    nickymarshall
    Oct 12, 2008
    1,048
    +198
    Thanks for your lengthy reply.
    Yep, I could send audio from Sky to the amp via ARC on the TV - I suppose that would be advantageous to allow use of the amp when watching Netflix etc via the tv app, rather than the BD player app
    Sending video only from the BD player to the tv would frustrate the mrs, as she may put a disc in and not want to turn the amp on. I'm aware of the tv's limited passthrough capabilities.
    I've read that sending the decoded HD sound codecs to the amp from the BD player via PCM over HDMI will give exactly the same audio quality as letting the amp decode, so will probably stick with that
  18. dante01
    dante01
    Mar 5, 2009
    45,164
    +10,617
    This isn't the issue, the issue is that if the HDMI connection between the player and the TV is set to convey audio then the player will not output any audio the TV cannot handle via either of its HDMI outputs. Your TV cannot handle multichannel PCM or the HD audio formats associated with Blu-ray titles. THe same issue would be apparent irrespective of whther you bitstream the audio or not and would still restrict the types of audio you can access even if not listening via the TV and using the AV receiver. You'd have to configure the player not to convey audio via the TV connection in order to circumvent this issue.
