Pcm On Blu-Ray Help
Discussion in 'Blu-ray & DVD Players & Recorders' started by SeeleyBooth, Feb 8, 2009.
  1. SeeleyBooth
    SeeleyBooth
    Apr 17, 2007
    7,334
    Staffordshire
    +489
    is it possible to get 96khz Pcm On Blu-rays
    The Handbook to My Sony Htsf1300 Says it can Handle 96khz Pcm but how do i Get it Has when i play A Blu Ray Recevier Displays 48Khz Pcm
    Ps How Much of a Difference is there if any bewteen 48Khz And 96Khz
    :smashin:
  2. Gadgetcity
    Gadgetcity
    Apr 2, 2008
    850
    43
    Christchurch, NZ
    +149
    Blu-rays discs support many audio formats. Not all have the same formats. If you connect via optical then your Sony only supports 48kHz. Optical can support 96/24 via DTS but the Sony doesn't support it.
    Over HDMI you can have up to 192kHz but your Sony says it only supports up to 96kHz.
    Your Sony will only accept this over HDMI as LPCM so you need to select DTS-MA or Dolby TrueHD on your Blu-ray player (if they are on the disc) and set the output to LPCM (not bitstream) and you should get the best sound available on your system.
    To be honest most people don't notice any difference between 48kHz and 96kHz. They both sound great!
  3. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Might be some music BD's with 96khz tracks?
  4. YellowSphere
    YellowSphere
    Dec 2, 2007
    4,448
    103
    +471
    Although there is support for 96kHz and higher sample rates on Blu-Ray, the vast vast majority of releases are 48kHz.
    Regarding telling the difference between the two. I would say it's generally more noticeable with music than movie sound. In a recording studio if you record at 96/24 then go back and record a retake at 44.1/16 the difference in quality would be easily noticeable.
  5. Ian_S
    Ian_S
    Dec 29, 2005
    7,163
    163
    +2,198
    Queen Rock Montreal - DTS-HD High Resolution 96/24.
    Turn up, sit back and enjoy, it's a cracker of an audio track. :smashin:
