Question PCM/DTS Pioneer Sound Problem
Discussion in 'AV Receivers & Amplifiers' started by alan8477, Dec 16, 2017.
Tags:
  1. alan8477
    alan8477
    Dec 17, 2001
    604
    Pershore
    +15
    I wonder if anyone can help me?
    I have a Synology NAS which services two separate Pioneer amps. One in a bedroom, and the other in the living room.
    The problem is that the one in the living room will not play certain PCM/DTS files. I have a copy of Black Rain (amongst others), which plays perfectly in the bedroom but not in the living room.
    Living Room Setup:
    Pioneer SC-LX97 receiver
    Dune B1 Smart media player
    nVidia TV
    Bedroom setup:
    Pioneer VSX-529-K
    Dune D1 Smart media player
    Raspberry Pi2 (Kodi OSMC)
    I should add that the files that present problems are old files, done at a time when I used to PCM almost everything. I haven't done this for some years. Files from that period that were Dolby sound play perfectly.
    I have checked that both systems are setup identically. I have tried both bitstream ( normally used), and PCM decoded at the Dune end. Makes no difference.
    Can anyone advise please?
    PS the sound I get is a loud hiss, which I assume means no decoding is taking place at the receiver end. I am assuming this is a receiver issue, as the output is the same on nVidia and Pi2.
