PCM digital output? Help!!!!!!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by candleman, Jan 25, 2004.
  1. candleman
    candleman
    Oct 21, 2003
    42
    oxford
    Hello all, I'm having difficulty finding which freeview boxes that have a PCM digital output, so I can plug it into my hifi DAC via an RCA digital lead. Any ideas???
    Dave
  2. Giles
    Giles
    Jul 25, 2000
    65
    UK
    I have a Sony VTX-D800. It has optical digital out, I got an optical lead this weekend, all works fine.
    Good picture, good software. No complaints with it at all.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,845
    Somewhere in South Yorkshire
    +5,078
    Pace 'Twin' has an optical digital output.
  4. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    The Pioneer has an optical output... Not sure if it outputs PCM out of the box... I would double check before purchasing...
  5. candleman
    candleman
    Oct 21, 2003
    42
    oxford
    Just so you know my DAC does not have an optical input, just the RCA.
  6. bxd
    bxd
    Oct 17, 2001
    1,482
    Southampton
    +136
    I'll also suggest the Pioneer. It's digital output will output pcm.
    Most of the available Freeview boxes probably have optical outputs as it's the more common digital input on 'budget' kit. You can buy a optical to coax converter from the likes of Maplin if you can't find anything suitable.
    Brian
  7. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
  8. CARLOS
    CARLOS
    Feb 11, 2001
    6,002
    WEST MIDLANDS
    +1,232
    Philips DTR1500 has a coaxial digital output and an excellent picture :smashin:
  9. candleman
    candleman
    Oct 21, 2003
    42
    oxford
    Thank you for the replies, i must say the nokia did look good, until I heard about the "freezing picture" and other bugs. Many people are down about the nokia box. Is it really that bad cos it sounds just the thing I'm after :confused:
    Cheers Dave
  10. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    Dave
    The Nokia has its problems as does every other STB out there, its more than just the STB & design of the boxes thats a problem, signal strength is another problem, weather conditions. Ive never had a problem with the 221T bar hanging once when flicking channels very quickly and that was one hang-up, Switched on/off fine. Go to Digital spy and read up about every other box they all have problems, in fact the Pace Twin & Netgem (both toslink optical) have the longest "problem" threads known to man IMO. But thats not saying the 221T is without problems they all have.
    I know for a fact that its the only one with a RCA digital out for sale currently, Pioneer or Phillips had a STB last yeat that was RCA digital output but has been superceded by a toslinked model. Im not saying its the be all & end all, but its the same as any other STB different areas seem to effect these boxes quite differently. Do a bit of a search on Digital Spy before discounting it dude, plenty of people like me like it. And as a DAC owner actively looking for a RCA PCM output I still think its the best VFM box on the market for your needs. I bought mine from John Lewis for £140 with a view if it did not work I would exchange it (they confirmed this when I bought it) for another.
    ATB
  11. candleman
    candleman
    Oct 21, 2003
    42
    oxford
    Cheers CJ, seems like my choices are limited, so I'm off to find the best deal on a Nokia!!
    Thanks all for the help
    Dave
  12. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Get a Tos to coax converter
