I searched, there's a ton of information on this topic I apologize in advance if this has already been posted.
I have a Yamaha rx-a1060 receiver connected to Vizio 4K TV. I have the TV audio output via optical (or HDMI ARC) set to bitstream only. I have several sources going directly into the Yamaha and have those set to bitstream as well. I prefer that the Yamaha do the decoding as that way I have more DSP options to try and see which one I like best. I also have a couple of sources going to my TV first (nVidea Shield, Nintendo switch, and PC computer). Sometimes I listen to these through my TV speakers, sometimes I want the audio sent to the Yamaha (via the optical output). If one of those sources sends a PCM signal to the TV (eg some shield apps don't give you the option of bitstream or pcm; in the shield audio settings, there is no bitstream only option), what gets sent to the Yamaha? Do I get the original full bitstream information or do I get only the PCM that got converted back to bitstream by the vizio. Example: Movies Unlimited app on shield, I play a movie that is 4K, HDR, and Atmos. Will I get an Atmos bitstream sent to my Yamaha or was a lesser PCM signal sent from the Shield and that was converted to bitstream by my Vizio?
