PCM and Denon AVC-A1SE
Discussion in 'AV Receivers & Amplifiers' started by VistaVision, Sep 18, 2007.
Tags:
  1. VistaVision
    VistaVision
    Feb 29, 2004
    272
    +21
    Can anyone tell me,please, if it is possible to use the Denon's 7.1 surround to access PCM sountracks on HD DVD/Blu Ray discs?
    Thanks.
  2. morksbeanbag
    morksbeanbag
    Jul 25, 2004
    723
    Chesterfield, Derbyshire.
    +49
    I doubt it very much, it'll be PCM 2 channel only.
  3. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    Not sure what you mean by access but if the player decodes it and outputs it to analog you can input it into the direct 7.1 sockets.
