PCI USB2 card with internal header connector
HiZ
My Compaq has usb connectors on the front panel with a lead to an 8 pin header motherboard connector. The motherboard is usb1 and I want to fit a usb 2 card so i can make the front panel connectors usb 2 also.
Tried here there everywhere but can't find a card. Most have an internal type A but not the header.
HiZ
Not sure it will work. The connextor is a 5 pin type and mine is the 8 pin type. I realise the two sides of the connector mirror each other and the end pin is only for a keyway but I'd prefer to get one with the 8 pin connector on unless you can confirm it will work.
