PCI riser card with an offset
Discussion in 'Desktop & Laptop Computers Forum' started by northernmunki, Jul 7, 2005.
  1. northernmunki
    northernmunki
    anyone know of a dual PCI riser card that will set off one PCI slot. If i use my standard dual riser it aligns with the PCI Express x 1 slot. I need to set it sideways left into the first PCI slot. I know flexible riser cards are available but i'd need two of them and they look a bit homemade!
    Aopen i915gmm-hfs into a LC02 case
    REgards,
  2. Skunkpipe
    Skunkpipe
    Nope there is nothing available for this sort of setup other than using the flexi risers (and I've looked a *lot*)
