pci graphics card install problem.
Discussion in 'Desktop & Laptop Computers Forum' started by tim k, Mar 23, 2005.
  1. tim k
    tim k
    just got a new p4 3 gig, has onboard graphics, but when i put the pci fx 5200 into the pci slot and power up windows cant find it, ive also tried wiring straight into it and boot and no luck either. am i being really stupid, whats wrong!!??
  2. betamac
    betamac
    Have you disabled onboard graphics?
    As it wont find a new card if onboard is enabled
    The option will be in the BIOS
  3. tim k
    tim k
    should i disable it in device manager in windows first?? or in the bios?? which card shall i connect vga to first!:?
  4. betamac
    betamac
    Connect VGA lead to motherboard onboard gfx slot, go into Bios disable onboard gfx, save - exit, then turn off PC install PCI gfx card and plug VGA lead into Gfx card and boot windows
    Windows should detect it and ask for drivers
  5. tim k
    tim k
    thanks mate, trying now, lets hope it works!! wish me luck !
  6. tim k
    tim k
    I cant find the onboard graphics option in my bios :(
    I found
    peripheral:
    onboard fdl
    onboard serial port
    onboard Infra Red
    onboard Parallel
    midi
    game
    ide
    lan
    audio
    modem
    another option said primary graphics adapter (pci/agp) selected pci as its ion the pci slot
    chipset config
    agp apeture size
    data rate
    fast write
    onboard vga share memory (Auto/32/64)
    help!!!
  7. DaveP
    DaveP
    You may not have a disable option but you should be able to chose a priority. Something like "Boot from First" with options like AGP/PCI. Strangely enough, I'd select AGP and see if that fixes it.
    I assume you dont get anything on the PCI card when you power up with the monitor connected? (Bios etc)
    BTW it's not a Dell is it?
    Dave
  8. tim k
    tim k
    no its not a dell its a home build p4 3 gig, ill try the agp option.
