PCI Express x16 question for a new graphics card
francisuk22
Hi all.
Im looking to replace my graphics card (Sapphire ATI Radeon X1550 PCI-E x16) My motherboards a asrock conroe 1333-d667, Question is would a evga nvidia geForce gt210 work? My new PSU is 750w now as im confused because
EVGA Nvidia GeForce GT210 - says PCI-E 2.0 x16
Sapphire ATI Radeon X1550 - PCI Express x16 - www.newegg.com/Product/Product.aspx?Item=N82E16814102704
Hmm :rolleyes::rolleyes:
Thanks for you help :)
paulktreg
Your Sapphire X1550 is PCI-E V1.0 but things have moved on as they tend to do! New PCI-E cards are all backward compatible so a PCI-E V2.0 graphics card will work fine in your motherboards PCI-E V1.0 slot. Your new power supply is more than enough.
EndlessWaves
Well you haven't actually mentioned what the rest of the system is so if you've got four 8-core Xeons and 20 hard disks in there then there may be some doubt, but for any system that didn't cost thousands of pounds 750W is a ridiculously high amount and will handle anything you throw at it, it will certainly have no trouble with a 15W graphics card like the G210. ;)
The G210 doesn't have many advantages over a X1550 though, are you replacing the old card because it was broken or are you hoping to upgrade to do something?
