Pci 2.2?
Discussion in 'Desktop & Laptop Computers Forum' started by K86, Aug 25, 2006.
  1. K86
    K86
    Dec 21, 2005
    197
    +4
    Hey
    I'm really sorry to bother everyone but I'll be moving to London soon but where I'll be staying I wont have access to a router close enough for me to link up to my PC (unless I connect an Ethernet cable from down stairs and trail it all the way upstairs which I kind of don't want to do :)) so I've been looking at wireless PCI cards but the ones I have been looking at need a PCI 2.2 socket and I can't find on my motherboard manufactures website if it supports it
    I have a ASUS A8N-E motherboard and the PC is pretty new (about 8 months) but only 1 site says that it does support PCI 2.2 (the motherboard has 1 PCI express input and 3 PCI inputs along with 2 AGP inputs) but I was just wondering if all motherboards shipped with it as standard come a certain time like the transition from USB 1.1 to USB 2
    I would be grateful for any advice for help with my problem
    Thank you
    K86
  2. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,255
    Essex
    +995
    looked in the manual ?
    or download manual from asus site...
    it should say in there .
    i doult a board that has pci-e would also have 2 agp slots.
    they proberly more then likely
    pci-e x 16
    pci-e x1 or x2 etc.
  3. K86
    K86
    Dec 21, 2005
    197
    +4
    Hey
    Thank you very much for getting back to me
    I’ve just looked in the manual and its says nothing about PCI 2.2 but I did find out what slots it has, here they are
    3 PCI slots
    1 PCI-E x16 slot
    2 PCI-E x1 slots
    1 PCI-E x4 slot
    if you would like more info on the motherboard here is the link to the site
    http://uk.asus.com/products4.aspx?modelmenu=2&model=455&l1=3&l2=15&l3=171
    Also I’m really sorry about the AGP slot, that was my mistake, sorry
    Thank you once again for your time
    Thank you
    k86
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    PCI specifications are managed by the PCI SIG (Special Interest group).
    PCI 2.2 is quite old (it was follwed by 2.3 and then 3.0).
    The Asus board you have will be backwards compatible with 2.2 but will support 2.3 or possibly 3.0 as well.
    So yes, the wireless card should be fine in it.
    Chris Muriel, Manchester
  5. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,255
    Essex
    +995
    hmm strange it doesnt say...
    nothing writing on the mobo around the pci slots ? like vx.xx etc
    hey no need to be sorry.. u made a mistake... thats all.
    we all do from time to time :)
    well u can always try asus support ?
