PC/Xbox LIVE! routers
Discussion in 'Xbox Forums' started by phenom2003, Jun 1, 2003.
  1. phenom2003
    phenom2003
    What is the cheapest router that can be bought to connect two pcs (both with network cards) and an XBox to a cable modem. Can I just use any router 3 port router or do I need any specific ones for LIVE! (read that some were incompatible)
    Thanks,
    Richard
  2. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    hello see my post in wireless xbox this should help you out:D
  3. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
