PC Won't Power Up
Bully9
Well, not exactly true because i'm typing this. The problem started yesterday when i pressed the power up button a couple of times and nothing happened. I was busy doing somethoing else and when i pressed it a little later the PC booted up. So i thought i'd just been clumsy earlier and not pushed the button properly.
But today the same thing happened. This time i paid more attention and I noticed that the power light on a multi card reader unit was flashing - something it had never done before. After a minute or so, the light stayed on and the PC booted up fine when i pressed the power button.
I unmounted the card reader with 'safely remove hardware' (4 'drives') and disconnected the lead to the motherboard - just in case the problem was related to this peripheral. But i'm scared to turn off and check the hypothesis in case i can't boot up again at all.
Do these syptoms suggest any likely cause to anyone? :lease:
Dingo
Fear of the unknown, fear of failure, fear of risk, fear of a dominant person in your life???
Or just fear of the bloody obvious?:facepalm:......check cables (replace and reboot) or boot with single HDD, memory, toothbrush and pyjamas..................GOOGLE IS your friend!!
Bully9
Actually, i did think of google myself. The problem is that there are so many similar scenarios out there, and so very many possible solutions, that i thought a post with my specific symptoms might bring a focused response.
For example, i would have thought that cables was highly unlikely under the circumstances i described.
Nevertheless, thank you for your time and trouble in responding.
