PC VGA - YUV conversion
Discussion in 'Cables & Switches' started by wolferl99, Oct 12, 2004.
  1. wolferl99
    wolferl99
    I am the owner of a Toshiba 57WH36P and I would like to connect it via its YUV port to my HTPC VGA port. I am thinking in acquiring a KD-VTCA3 VGA-YUV converter. Is anyone here using one of these devices? I'm interested which resolution I could convert with it. I kind of gave up with 720p, because I understand that the Toshiba does not accept HDTV on YUV. But even standard PAL should be superior to S-Video, right?
    thanks wolferl
