pc vga input
Discussion in 'General TV Discussions Forum' started by Baz1, Sep 21, 2003.
  1. Baz1
    Baz1
    Dec 11, 2002
    169
    16
    Workingon, Cumbria.
    Hi there,
    Looking for some help.
    I have a LG 32'' widescreen tv, and it has a PC input 640 x 480.
    What DVD players can I use with this tv, using the vga input.
    There is only 1 RGB scart, so I thought I maybe able to use the VGA input and leave the RGB scart for sky tv.
    Also does anyone know if the picture will be ok or not.
    Thanks,
    Barry
    :hiya:
  2. Piya
    Piya
    Feb 6, 2002
    Leeds
    Hi Barry
    I don't think there is any dvd player that has a vga output to connect to your LG vga input. However, some dvd players have progressive scan component video output that you can use with a transcoder to convert signals for your LG vga input. I never use one so I'm not sure how well it works.
    I've got a Grundig 32" Xantia that has a vga input. I connect it to my HTPC @ 856x480 resolution and the picture is awesome. It is not as convenient as a standalone dvd player though.
    If you have a pc nearby, you can try it for your self. Look at HCPC forum for more instructions as how to configure a pc as a home cinema.
    Piya
