PC upgrade and USB 3 and PCI 3
Discussion in 'Computer Components' started by claytonchris2k, Jan 7, 2012.
  1. claytonchris2k
    claytonchris2k
    Jan 6, 2012
    13
    Nottingham
    Hi guys/girls
    Im looking at upgrading my pc everything but my GPU and PSU I'm going for the Intel I5 2500k (for overlooking) just need to choose a nice mobo if anyone can throw me a few ideas.
    But I was just wondering is USB3 and PCI 3 backward compatible ? As the cases I'm looking at have USB2 ports and USB3 ports that's what makes me think they are different
    Also sorry I'm asking loads of questions but is this LCS a nice kit
    http://www.scan.co.uk/products/ek-kit-h3o-supreme-hf-360-en
    Thanks for reading
    Chris
  2. shadowboxer
    shadowboxer
    Mar 15, 2010
    1,571
    Staffordshire
    +196
    Yes you can use USB 2.0 devices in a USB 3.0 slot and same for PCI-E 3.0 you can used older GPUs.
    Have you read any reviews of the latest 7900 series card from AMD? See link. Basically shows that there is virtually nothing gained by putting the 7970 in a PCI-E 3.0 slot over the 2 slot. I'm sure things will change in a few years though...
    (Link)
  3. claytonchris2k
    claytonchris2k
    Jan 6, 2012
    13
    Nottingham
    hi Shadow thanks for that i guess it would just couldn't understand why they have USB3 and then also USB2 ports if you can use them both in 3
    Thanks for the help
  4. FDM
    FDM
    Dec 30, 2011
    Well this is a blow. I am looking at getting the new AMD GPU, my mainboard I'm waiting on delivery only supports PCI 2.0 am I better getting a refund and buying a 3.0?
  5. claytonchris2k
    claytonchris2k
    Jan 6, 2012
    13
    Nottingham
    I would say don't cancel PCI 3 is only in its early stages so you looking at sometime before its really used. I dont think the board I will be getting has PCI 3
  6. claytonchris2k
    claytonchris2k
    Jan 6, 2012
    13
    Nottingham
  7. shadowboxer
    shadowboxer
    Mar 15, 2010
    1,571
    Staffordshire
    +196
    • Much cheaper 2x4GB RAM kits avaiable if colour doesn't matter to you.
    • Go for the Crucial M4 128GB SSD. More reliable.
    • That is a very very expensive PSU, much cheaper ones will do the job just as well.
    • Getting a custom water loop rather than a all in one package will be much better and not a whole lot more expensive.
    • I would be looking to get a Gen3 Z68 motherboard to it is compatible with Ivy Bridge.
    What speakers/headset have you got?
    GPU?
