PC-ULTRA vs PB12-PLUS/2
Discussion in 'Subwoofers' started by figlio, Mar 4, 2005.
  1. figlio
    figlio
    Dec 17, 2002
    180
    Malta
    I am interesting in buying one of these subs?Which one do you recommend between these 2 subs.The price is nearly the same.I am going to use it 80% movies 20% music.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,672
    I chose the PC-Ultra for my system,having looked at both the models you've mentioned,plus the PB12/Ultra.
    I decided on a cylinder model in the end,as I need something that can be easily placed,and doesnt take up too much space,and the PC-Ultra fitted the bill perfectly....so far(and I've only had it for a few days),it's an excellent sub overall...fast enough to work very well on music,and has excellent extension and control.
  3. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    If your room is of stadium proportions, then the PB12 Plus/2 would be the better buy, if it is a normal sized room, then the PC Ultra would be the better buy :) I love my PC Ultra :) It's luurrrrrvly.
    You'll get Smurfin coming on in a moment though screaming about headroom :D but don't listen to him, he's mad, lovely, but mad.......why mad? He has just bought TWO PB12 Ultra /2's!!! :eek: If you can afford to buy two PB12 Ultra /2's, then do that instead :)
  4. Audionyx
    Audionyx
    Dec 10, 2002
    697
    North Yorkshire
    +28
    Hmm, I am also in the same position - considering an upgrade from my MJ Ref 150.
    I really like the look of the PB12-Plus/2 but somehow don't think it will get pass the Mrs' strict approval criteria - hang on a minute, who wears the trousers?
    So if they deliver similar amounts of bass and slam then perhaps the cyclinder may pose less of a hassle to convince of the merits!?
    Kazman, did you not get my PM re questions about shipping from US?
  5. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    Hi Darren
    I can't remember it :( (I get sooo many PM's with questions now a days its sometimes hard to keep up). Apologies if I missed it.
    You should find this link helpful http://www.avforums.com/forums/showthread.php?t=121385
    Should cover all you need to know about shipping from the US and buying from SVS :)
    If you need any more help, let us know :).
  6. Audionyx
    Audionyx
    Dec 10, 2002
    697
    North Yorkshire
    +28
    Kazman,
    No worries mate - I was quite drunk when I wrote it and wondered if my etiquette may have been lost in a bottle or two of Warsteiner!!
    I saw that post re the shipping after I had PM'd you and found it very useful.
    Take it easy
  7. Des Flurane
    Des Flurane
    Mad Darren,
    I'm in the opposite camp, my wife hates the cylinder but gives consent ( loves would be too strong a term!) for the plus/2 box.
    The clincher was Bass-Oldie's pictures with lamps, plants and ornaments on top of the box!
    The sub will be behind the sofa, so mostly out of sight.
    Just waiting for a shipping quote from Ron.
    Des.
  8. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,452
    South Shropshire
    +88
    Just bear in mind that no matter how big you think the pb12-plus2 will be, it is in fact bigger when it arrives!
    Obviously the dimensions are correct but I even went to the extent of making a cardboard box the same size to imagine how it would look but it was still a shock when it was carried on its pallet into my lounge!
    Love it to bits though!
  9. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    I was amazed when my PB12-Ultra/2 arrived, it barely fit through the door & corridor. Imagine if I had opted for the PB12-Plus/4, that was in B-stock for $2000 at that time, which is almost 1.5x as wide! :eek:
  10. Rip
    Rip
    Aug 30, 2004
    561
    Trowbridge
    +42
    Hi Ettepet, i am about to order a PB12-Ultra/2 very soon, can you tell me what sub did you have before the Ultra, & how they compare. Also, you must of had a chance to give it a good play with by now , so what do you think of it ?
  11. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    Hi Rip,
    The Ultra/2 is doing fine. :D
    I have owned several items that have inspired months-long (almost) butterfly feelings, and after improving the accoustics of my apartment, the PB12-Ultra/2 is certainly one of them. :thumbsup:
    Previous "Audio-winners": a Yamaha RX692RDS + beautiful remote :blush:; the Yamaha SW800 sub (which I still own), and my versatile and very capable Pioneer AX10. Strange enough I never felt nearly as comfortable with the PB12-Plus/2, my previous subwoofer.
    My advice would be: if you cannot make your own IB (f.i. here: link), don't need 16Hz or lower tuning, and can afford it, the Ultra/2 is a fine choice indeed!
