PC TV Tuners Capable of WUXGA?
Discussion in 'Desktop & Laptop Computers Forum' started by stretchneck, Mar 7, 2005.
  1. stretchneck
    stretchneck
    Are there any internal or external TV tuners which are capable of WUXGA (1680 x 1080) output as default?
  2. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    The display resolution should not be related to the TV tuner card. If your display is 1680 x 1050 then a full screen display should be scaled to that regardless of the source resolution, unless the supplied software is very bad indeed.
  3. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    Which display has 1680 x 1080 resolution?
    In any case you are in luck as any PC TV tuner card would work with it. I wholy recommend DigiTV from www.Nebula-Electronics.com .
  4. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    It may be a laptop. I bought a laptop last year with a 1680 x 1050 display. It's a good compromise between decent resolution and cost.
