Pc-tv play a movie
EndlessWaves
What's the problem you're having, can you get the PC to display it's desktop on the TV and it's just the movie not working?
Iccz
What is the make and model of your laptop?
And if you know is the graphics card ATi or Nvidia?
Batch
Are you mirroring the desktop or extenending it?
Batch
Does the movie play on the laptop screen, or not at all?
Is the 2nd screen black, display anything, any flickering?
What happens if beneath where you select the 2nd screen, you choose to set it as your primary monitor?
eddgreen25
The movie plays on laptop
The tv screen shows the desktop screen with no icons
Only the netmeter icon
No other item is listed
There's no flicker
Reselution choice under monitor choice
Choice after choosing moniter {2}
Batch
mmm, ok. Are you using Vista or XP? I'm guessing XP. Also, are you able to drag any icons, either off the left or right of laptop screen and have them appear on the TV?
eddgreen25
I'm using Vista
No icons on tv to move around the screen
Only netmeter
Which as a novice I dont understand
Micray
eddgree, do you have a key on your laptop, usually along the top row, that is marked LCD/CRT. Its normal to have a key like this, which when pressed, sometimes along with a function key, toggles between your laptops screen and external output. in this case your T.V.
eddgreen25
no key marked LCD/CRT
Micray
Well it may be marked differently on your laptop, maybe with a monitor icon.
However there should be a key to toggle between your laptop screen and an external screen or both.
You may find that its sharing the screen between your laptop & TV. If you move your mouse pointer around to all extreams does it show moving from the laptop screen to the TV screen or on both at once?
eddgreen25
cant see a key with a moniter on sorry
eddgreen25
update ive found the keys are F7 and FN
this takes me in another screen
were do i do from here
Micray
Ok, now pressing the fn & F7 several times should go through all the options available on your laptop. These being laptop only, TV only and Laptop & TV together. There may also be one for laptop & TV as one shared screen.
The last being the one you seemed to be describing. Go through them one at a time and try them out and se what you can get. GL.
eddgreen25
Thanks Micray for your help
